Go Back   SemiAccurate Forums > Main Category > Misc Technology
Misc Technology Other technology related discussions
Old 04-28-2010, 05:23 PM
phaxmohdem's Avatar
phaxmohdem phaxmohdem is offline
itanic
phaxmohdem is on a distinguished road
Default Flash Memory Transistor count?
I just got to thinking for some random reason today... How many transistors does a flash memory chip have (like that in an SD card)? Would an 8GB chip contain 64 billion transistors; one for each bit of information? If so they would have to be stacked vertically somehow right? I mean Fermi, with "merely" 3.1 Billion transistors or so is larger than an SD card by itself.
This sig brought to you by the makers of ePeen++
---( Phenom II X4 940BE || ASUS M2N32-SLI Deluxe || 8GB G.Skill PC2-6400 DDR2 || eVGA 8800GTX & eVGA 8600GT (Quad Monitors) || Vertex 2 120GB SSD & 1TB Caviar Black HDD || Das Keyboard Professional || Logitech G5 Mouse || Fractal Design Define R3 Case || Seasonic 700HM PSU )---
Old 04-28-2010, 05:51 PM
toughluck toughluck is offline
2^10
toughluck will become famous soon enough
For MLC (like SD), divide the number of bits by half (2 bits stored per cell). That's still 32 billion for an 8 GB chip, and will still reach over 100 billion for 32 GB SD cards.
I've never given it any thought, but now it's intriguing. Most SSDs on the market use somewhere around 8 GB flash ICs in their drives and will likely increase the size in the future, which adds up to huge transistor counts.
Old 04-28-2010, 07:51 PM
DavidC1 DavidC1 is offline
8-bit overflow
DavidC1 is on a distinguished road
Certain circuits are much denser than others. NAND flash is probably one of the densest out of all of production grade technology. The least densest circuitry lies in the processing core of the CPU, and well, maybe the I/O devices like memory controllers.
Cache is much denser than CPU logic, but they use 6 transistors. NAND flash only needs 1. Even then, real world differences are MUCH greater.
IMFT 4GB 34nm Flash die: http://www.anandtech.com/show/2928
172mm2 for 4GB
Intel 32nm SRAM wafer 291Mbit(36.375MBytes): 1.9 billion transistors, likely near 100mm2. Intel's 90nm wafer had 52Mbit test chips with 109mm2 die. Transistor for transistor, mm2 for mm2, MB for MB flash is 10x dense than 6T SRAM used in caches.
Old 05-05-2010, 11:21 AM
rambaldi's Avatar
rambaldi rambaldi is offline
2^11
rambaldi will become famous soon enoughrambaldi will become famous soon enough
While we are at it how many transistors would the "uncore" of the Flash memory chip take? I know it is probably pretty insignificant in comparison but I was just wondering (but not enough to go look it up and work it out )
E-Peen: AMD Phenom II x4 965 (stock) | MSI 790FX-GD70 | ATI HD 5970 (stock) | Kingston HyperX DDR3 1333 CL7 2x2GB | Seagate 7200.12 4x1TB | Ikonic RaX10 Liquid
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
SemiAccurate is a division of Stone Arch Networking Services, Inc. Copyright 2009 Stone Arch Networking Services, Inc, all rights reserved.
